What cRIO Controllers Are Compatible with GOOSE VIs for IEC 61850
Updated Dec 20, 2023
  • CompactRIO Controller
  • LabVIEW Real-Time Module
  • NI-Industrial Communications for IEC 61850 15.0
I would like to utilize the GOOSE VIs of the NI-Industrial Communications for IEC 61850. What hardware can I use these VIs with?
NI cRIO-906x and NI cRIO-903x are compatible with the GOOSE VIs in NI-Industrial Communications for IEC 61850.
A more comprehensive list of supported hardware and software for NI-Industrial Communications for IEC61850 version 15.0 is listed below:
NI Hardware Support
IEC 61850 VIsNI Hardware Support
SMV VIsNI cRIO-906x and NI cRIO-903x
GOOSE VIsNI cRIO-906x and NI cRIO-903x
MMS VIsAll NI CompactRIO real-time controller and all NI PXI real-time controllers
NI Application Software Support
NI Application SoftwareVersions Supported by NI-Industrial Communications for IEC 61850
LabVIEW2012 (32-bit), 2013 (32-bit), 2014 (32-bit), 2015 (32-bit)
LabVIEW Real-Time Module2012, 2013, 2014, 2015
