Why Does TCP Open Connection VI Work With A Port Number But Not A Service Name?
Updated May 31, 2018
I am building a TCP application and when I use a named service to connect to my server the "TCP Open Connection.vi" times out, but always connects across my network when I have a port chosen.  Why does it not find the service name?
This is most likely due to a firewall or network security issue.  You can try disabling your firewall or have IT assign you a port for your application that you can then use instead of a named service.  You can also try opening your Firewall Settings and add the NI Service Locator to an exception to the firewall.
The issue is that when you target a port exactly, your application on the server computer is handling the communication and therefore will be able to respond.  When using a named service, Windows will assign a port dynamically to your application on the server side which the client will have to request access to through the Windows Firewall.  Windows may interpret this as a security violation and not allow NI Service Locator to function properly.
