Create a New SequenceCall Step and Modify Its Properties with the TestStand Engine API
Updated May 2, 2018
  • TestStand
I am dynamically adding steps to my sequence file with the TestStand engine API and I want to create a SequenceCall step that calls a sequence by name.
Here is one way to create a SequenceCall step and dynamically set some properties:
Locals.NewStepRef = RunState.Engine.NewStep(RunState.Engine.DefaultAdapter, StepType_SequenceCall),
Locals.NewStepRef.AsSequenceCallModule.UseCurrentFile = True,
Locals.NewStepRef.AsSequenceCallModule.SequenceName = "MySequenceName"
Where Locals.NewStepRef is an Object Reference.
TestStand Object References have API methods in the form of As<object type> to convert the generic object to a more specific type. In the above example, Locals.NewStepRef is an Object Reference that needs to be cast to a SequenceCallModule object with the AsSequenceCallModule method. This exposes the properties and methods specific to the SequenceCall step.
