LabVIEW FPGA Module 2022 Q3 and onwards:
The 64-bit version of the LabVIEW FPGA Module added compilation support for the following targets:
- CompactRIO: cRIO-903x/904x/905x/906x - requires CompactRIO 2022Q4 or newer
- Single Board RIO: sbRIO-96x7/96x8/96x9/9603/9651 - requires CompactRIO 2022Q4 or newer
- R Series PCIe: PCIe-782xR/784x/785x (Except the PCIe 7841/2R)
- R Series PXIe: PXIe-782xR/784xR/785xR
- Note: PXI-7841 and PXI-7842R do not have PXI Express variants
- R Series USB: USB-784xR (OEM)/785xR (OEM)
- Ethernet RIO: NI 9147/9149
- Industrial Controllers (with NI Linux RT): IC-3120/317x
- Vision-RIO: PCIe-1477
LabVIEW FPGA Module 2021 SP1 and older:
The 64-bit version of the LabVIEW FPGA Module supports bitfile compilation for select modules in following hardware lines:
- USRP RIO devices
- PCIe-576x/577x/5785/798x
- PXIe-5163R/5164R/517xR/5745/576x/577x/5785/659xR/7902R/791x/797xR/798x
This list includes:
- FlexRIO devices
- High-Speed Serial devices
- Vector Signal Transceivers
- Vector Signal Analyzers
- Vector Signal Generators
- Reconfigurable Oscilloscopes
Note: This is the hardware range supported as of LabVIEW FPGA Module 2021 64-bit. For a list of supported hardware in a different version, refer to the version's Readme document, which can be found on the download page (refer to Related Links).
Devices where bitfile compilation is not supported by LabVIEW FPGA 64-bit can be used, when the bitfile is compiled using LabVIEW FPGA Module 32-bit. The 64-bit software support for the NI CompactRIO and NI R Series Multifunction RIO drivers allows communication with the bitfiles using the LabVIEW FPGA Module 64-bit, but not programming.
