Error -88900 in NI MAX
Updated Jun 12, 2025
  • CompactDAQ Controller
  • cRIO-9040
  • cRIO-9041
  • cRIO-9043
  • cRIO-9046
  • cRIO-9045
  • cRIO-9048
  • cRIO-9049
  • cRIO-9042
  • cRIO-9055
  • cRIO-9054
  • cRIO-9056
  • cRIO-9057
  • cRIO-9053
  • cRIO-9058
  • When expanding the Devices and Interfaces subtree under my Linux Real-Time (RT) target compatible with the NI-DAQmx driver, I can see that the chassis and/or the C Series Modules connected to it have a red "x" next to them. When selecting them, NI MAX displays error -88900.
  • When attempting to expand/open NI-DAQmx Global Virtual Channels under Data Neighborhood in an NI-DAQmx compatible RT target, NI MAX hangs for 4 to 6 minutes before it returns a list of global channels. After the list is returned, if I click on one of the global channels, the right pane displays error code -88900.
    Error -88900 occurred at Device Communication
    Possible Reason(s):
    The specified remote target is not reachable. Ensure that the target is running.
The error is shown in the following dialog box:
This error may be caused due to different reasons. The most common ones are software incompatibilities or hardware issues. If you are seeing this error in NI MAX, there are a few troubleshooting steps and considerations:
  • Check the Readme of the drivers to confirm compatibility of the driver version with the hardware/OS/software version. You can use the following documentation as a guide as well: Software Support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT.
  • Verify that the NI-DAQmx driver version you have installed on your real-time target is the same one available on your development PC.
  • Check Windows Device Manager for the DAQ devices. If the device shows up in Windows Device Manager, try the steps listed in the following article: DAQ Device Not Listed in MAX But Shows Up in Windows Device Manager.
  • Check the pins on the modules and cables for any damage or bent pins. This can cause miscommunication if there is not good contact between the points.
  • Try different cables/ports for the hardware. Sometimes ports or cables can be corrupted or damaged.
  • It is important to be aware of the Installation Order for Multiple NI Software Products . If LabVIEW is installed after the drivers, LabVIEW will not be able to recognize the drivers to use. If the original configuration was correct and later you upgrade/update LabVIEW, you may need to repair your other software to allow them to be recognized as being installed after the upgrade/update.
  • This could happen due to a corrupted installation and dependency issue between the NI-TimeSync and NI-DAQmx drivers. Make sure to upgrade those two driver versions together. Reinstall NI-DAQmx on the target if the issue persists.
  • The error may occur due to a corrupted system image deployed on the target. Use the methods of Replicating and Deploying NI Real-Time System Images article to redeploy the system image.
