Resolving Error 200018 in NI SignalExpress
Updated May 30, 2018
  • SignalExpress
I am receiving the error 20018 in NI SignalExpress while trying to generate an analog input.
Under possible reasons I see that I should decrease the output frequency. How can I do this in NI SignalExpress?
To reduce the output frequency in NI SignalExpress select the DAQmx Generate Step. In the Configuration tab, under Timing settings you should uncheck the Use Waveform Timing checkbox as shown below:
This should allow for the Rate to be modified, this value should be lowered in order to correct this error.
