Supported RAID Levels of HDD-8261
Updated May 24, 2018
  • HDD-8261
I would like to configure and enable RAID (Redundant Array of Independent Disks) for drives mounted in HDD-8261. Where can I find the information which RAID levels are supported by this Data Storage Module.
NI does not specify supported RAID levels for HDD-8261, since this module uses Marvell SATA controller, which does not have a built-in hardware RAID.
Available RAID configurations depend on the Operating System you are using as the RAID communication of HDD-8261 relies entirely on the Operating System and the CPU.
More information on how to create RAID with Windows Operating System can be found in HDD-8261 Getting Started Guide (page 7)
