Teststand Get the Same File When I Use the FTP Files Step Two Times in the Same Sequence
Updated May 18, 2018
  • TestStand
I use TestStand. When I try to get a file from my target with the FTP Files step, I always get the same file.
How can I fix that ?
To correct that, you must configure the step Unload Options as Unload after step executes :
  1. Click on your FTP Files step
  2. Select the Properties tab
  3. Select Run Options
  4. Chose Unload after step executes in the Unload Option field
