Accessing Additional Serial Ports on sbRIO RMC Connector
Updated Oct 15, 2021
  • sbRIO-9627
  • NI-RIO
Other
sbRIO CLIP Generator
I'm using sbRIO-9627 and I would like to access additional peripherals like RS-485 and RS-232 via RMC connector. I'd like to design and build a specific RIO MEZZANINE Card. What should be done in LabVIEW to see and access these ports from Project Explorer?
To add optional peripheral interfaces to Project Explorer in LabVIEW, you will need to:
  1. Create a Socketed CLIP, which gives access to I/Os, that are not accessible from LabVIEW FPGA VI.
You may use sbRIO CLIP Generator, which is a tool included in the NI-RIO Driver, to automatically generate suitable socketed CLIP. (Detailed information about what a CLIP is, how to navigate through the sbRIO CLIP Generator you may find in the presentation attached to this forum thread.)
  1. Return to LabVIEW, right-click RMC Socket under the FPGA Target, and select Properties.
  1. In the Socket Properties dialog box, select your CLIP and click OK.
The I/O, and ports selected in Socketed CLIP will appear under the socket in Project Explorer.
You can create your own RMC to integrate your own specific analog I/O, digital I/O, communication capabilities, and signal conditioning by combining these components onto a mating printed circuit board (PCB), known as an RIO MEZZANINE Card.
Detailed information about RMC design techniques, guidelines, and requirements can be found in RIO MEZZANINE CARD DESIGN GUIDE.
RMC Connector Pin Listing, RMC Connector Feature Set Compatibility, and electric connections are described in sbRIO-9627 User Manual (starting page 37)
