Can I Rotate a LabVIEW Front Panel Indicator?
Updated Sep 30, 2025
  • LabVIEW 2017 Full
I would like to rotate a string or numeric indicator 90 degrees on my front panel. Can this be achieved?
Within LabVIEW you are only able to set the vertical alignment of a label, caption, or free label. See error 1453 in General LabVIEW Error Codes
There are possible workarounds, depending on what your coding goals are. Refer to the example in the screen shot below for one option. (Downloadable in the Attachments section.)
Feel free to make feature requests in the LabVIEW Idea Exchange forum
