Removing Border from LabVIEW NXG Web VI Panel Button
Updated Apr 26, 2018
  • LabVIEW NXG 2.0 Web Module
  • I am placing¬†buttons on my LabVIEW NXG Web VI Panel but don't want the white border to be visible. How do I remove that inside border?
  • You can modify the outline-offset property of all buttons on your panel by creating a new <style> section¬†on the HTML panel and adding the text shown in the image.
  • If you want to remove the white border on a specific button instead of all buttons on the WebVI's Panel, you can use the value from the CSS selector item in the configuration pane on the right side when you select the control instead of jqx-toggle-button.
