Understanding The NI 6361 Current Specifications
Updated May 10, 2018
  • USB-6361
  • PXIe-6361
  • PCIe-6361
I am looking to use the NI 6361 +5V output for my application but am not sure what is the maximum current output from my device. Where can I find this?
The maximum current you can draw from your device is detailed in the device datasheet which you can find here under the Current Limits section. Please ensure you are using the correct value depending on whether you are using the PCIe, PXIe or USB variant of the device, as described in the documentation.
