Can the REM-11180 Work With Third-Party Controllers?
Updated Jun 15, 2018
  • REM-11180
I am interested in using the REM-11180 with my third-party Controllers that are enabled with EtherCAT. Can I control the REM-11180 this way?
The REM-11180 is designed to work with NI's controllers such as our compactRIO platform or Industrial Controllers.
You may be able to implement the REM-11180 as an etherCAT slave using third-party controllers but it would likely require a custom implementation.
