With the NI VeriStand .NET API you can programatically choose a computer to serve as the gateway system to deploy a SDF which can also be defined programatically. The following example program shows the use of this API to
deploy an SDF from LabVIEW.
An example for ANSI C is avaible in the documentation for the API which can be found with the documentation of the API, which is located in C:\Program Files (x86)\National Instruments\VeriStand 2017\Help, in the Execution API Programming Concepts section.
