Start Clock Servo.vi Returns Void Variant Session
Updated May 15, 2018
  • PXIe-6674T
  • PXI-6682
  • PXI-6653
  • PXI-668XH
  • NI-Sync
When using the Multi-device PXI_Clk10 Disciplining library, I noticed that Start Clock Servo.vi seems to output a void variant. Is it really outputting <void>?
Session data is being passed. The probe just isn't capable of interpreting the data's structure.
If this was found during troubleshooting, try performing an I/O Trace on these VIs to help identify calls that are failing.
If you have problems loading the VIs in this library, you may need to install NI-Sync.
