Do I Need a Timing Card to Implement NTP Synchronization with PXI?
Updated May 18, 2018
  • PXI Synchronization Module
I am trying to synchronize my PXIe-8880 controller with an NTP server. Do I need an additional timing card to do this?
No, you do not need a timing card for NTP synchronization. You would only need an additional timing card if you wanted to implement PTP, IEEE 1588, PPS, IRIG-B, or GPS synchronization in your system.
