The table below lists the various protocols that can be implemented on NI High-Speed Serial devices. In addition to existing protocols, it is also possible to implement custom protocols with NI High-Speed Serial devices. To check if our devices are electrically compatible with your custom protocol, please reference the device specifications document.
In the table below, the first column includes items where a reference design exists in the form of LabVIEW sample projects. Items in the middle columns mean that IP exists for the protocols, and NI devices are electrically compatible, but we have not implemented it in LabVIEW so there are no existing LabVIEW sample projects. The items in the last column are not electrically compatible with our High-Speed Serial devices.
| Existing LabVIEW Sample Project | Xilinx IP but no LabVIEW Sample Project | 3rd party IP other than Xilinx | Not Compatible |
| Xilinx Aurora 64b66b (*HSS 14.0 and later) | SDI | SFPDP | MIPI |
| Xilinx Aurora 8b10b (Link to Example) | 40G Ethernet | V-by-One | USB |
| 10GbE (**HSS 15.5 and later) | DisplayPort | Fibre Channel | PCIe |
| Gigabit Ethernet (***HSS 16.1 and later) | XAUI | | CSI-2 |
| CPRI (****HSS 14.0) | Interlaken | | D-PHY |
| JESD204B (Link to Example) | | | |
| Serial RapidIO (Link to Example) | | | |
Table notes:
*Shipped example included in LabVIEW Instrument Design Libraries for High-Speed Serial Instruments 14.0 and later versions.
**Shipped example included in LabVIEW Instrument Design Libraries for High-Speed Serial Instruments 15.5.0 and later versions.
***Shipped example included in LabVIEW Instrument Design Libraries for High-Speed Serial Instruments 16.1 and later versions.
****Last version compatible of LabVIEW Instrument Design Libraries for High-Speed Serial Instruments.
