How To Set SoftMotion Limit Switch's Active State
Updated Jun 15, 2018
  • LabVIEW SoftMotion Module
How do I change the default active state for my home and limit switches in SoftMotion?
You can set these properties in your Axis Configurations by Right Clicking Axis and selecting Properties
In the Axis Configuration Dialog Box Select Limits & Home and you can set the Active State here.
You can also set this property programmatically with the Active State Property.
