Extract Multi-Channel TDMS Data in LabWindows™/CVI™
Updated Jun 15, 2018
  • LabWindows/CVI
I am using LabWindows/CVI and I want to extract the data on column B “Dev1/ai2” in the tab “Groupname” in the attached TDMS file. Which function call(s) and what parameters should I use?
Start with the TDMS Reading Data Basics section in the CVI TDMS Library White Paper. That example code reads one channel of data from a TDMS file. You can refer to the attached example to see how to alter the code to read from a TDMS file with two channels.
