NI 9144 EtherCAT Chassis is Not Recognized by NI MAX
Updated Feb 13, 2019
  • NI-9144
  • PXIe-8135
Programming Language
  • LabVIEW G
I have the NI 9144 EtherCAT chassis and it is connected to the NI PXI(e) RT embedded controller which has got two Ethernet ports. Port1 of the NI PXI(e) RT embedded controller is connected to the Host PC and Port2 is connected to the NI 9144 EtherCAT chassis. The NI PXI(e) RT embedded controller is recognized by the NI MAX. However, NI 9144 EtherCAT chassis is not recognized by the NI MAX. How to resolve this issue?
It is expected behavior that the NI-9144 will not be detected in NI-MAX. The NI-9144 EtherCAT chassis will only appear in the LabVIEW Project.
TheĀ Setting Up EtherCAT on NI Programmable Automation Controllers tutorial provides step-by-step instructions to help you set up your EtherCAT system using NI programmable automation controllers (PACs) and NI LabVIEW graphical programming.
The step-by-step instructions provided in the Setting Up EtherCAT on NI Programmable Automation Controllers tutorial is same for the NI PXI(e) RT embedded controllers and NI CompactRIO Controllers.
