TestStand Engine Shutdown Causes TestStand to Crash
Updated May 1, 2018
  • TestStand
When I attempt to shutdown TestStand from within my application using the TestStand Engine Shutdown (Engine.ShutDown(final)) it causes TestStand to crash each time, how can I correct this?
When using the TestStand Engine Shutdown (Engine.ShutDown(final)) if you haven't closed each of your references within TestStand appropriately it will cause TestStand to crash. To work around this you can verify that you have successfully closed out each of your references prior to shutting down the TestStand Engine or you can call the "Exit" button in Windows which will also close the application.
