Terminal Configuration on the PXIe-4300 in VeriStand
Updated Apr 18, 2018
  • PXIe-4300
  • PXI Analog Input Module
  • VeriStand
I am using the PXIe-4300 in my NI VeriStand application. I can only see 8 channels available to use, which makes sense since this device supports 8 differential analog inputs. However, I want to use this device in a single-ended terminal configuration. Can I do this?
The PXIe-4300 only supports a differential terminal configuration, and cannot be used in referenced single-ended or nonreferenced single-ended terminal configurations in any DAQmx application.
Using NI DAQ Hardware Modules in VeriStand will automatically show what is supported for the DAQ device. In NI MAX, you can create a task and configure the terminal configuration, but you will see that every configuration option expect for Differential is grayed out.
