The LabVIEW Modules are only compatible with the version they are built for. For more information about compatibility, review the readme file of each module. This is also true for SP1 versions only if there was a released SP1 version of that LabVIEW Module.
You can check the LabVIEW FPGA Module and LabVIEW Real-Time Module download pages to see if there is a SP1 version released for that year.
For example:
- The compatible versions of LabVIEW 2017 SP1 are the following:
- LabVIEW Real-Time Module 2017
- LabVIEW FPGA Module 2017 SP1
- The compatible modules for LabVIEW 2018 SP1 are the following:
- LabVIEW Real-Time Module 2018 SP1
- LabVIEW FPGA Module 2018
When installing LabVIEW, LabVIEW Modules, and NI drivers on your development computer, the order in which you install the software is important. Refer to the Getting Started with CompactRIO Hardware and LabVIEW tutorial for more information about software installation, activation, and configuration instructions.
