Change the Value of a Field in a TestStand Report
Updated Feb 11, 2020
  • TestStand
I want to change the name of a step in my results processing programmatically.
TestStand collects results during execution and places them in the ResultList. The ResultList is used to generate a report in Results Processing. To change the name of a step in the report, you can modify the property in ResultList prior to report generation. In this case, modify Locals.ResultList[STEPINDEX].TS.StepName.
