このコンテンツは設定された言語で表示できません。
Ethernet cDAQ Chassis Is Unusable After Updating The Firmware
Updated Feb 25, 2025
  • cDAQ-9188
  • cDAQ-9183
  • cDAQ-9187
  • cDAQ-9189
  • cDAQ-9181
  • cDAQ-9184
  • cDAQ-9185
I have an Ethernet CompactDAQ (cDAQ) chassis and have updated the firmware in response to a DAQmx update. The device now powers on and has a solid yellow status light, which remains solid indefinitely. The device does not show up in NI Measurement & Automation Explorer (NI MAX) or the Windows Device Manager, and appears to be bricked.
Network cDAQ chassis can have their firmware corrupted during updates in some rare cases. When this happens, the cDAQ should be put in recovery mode. Once in recovery mode, the Network cDAQ Recovery Utility will reset its firmware, and the update can be retried.
To put the cDAQ in recovery mode, perform the following steps:
  1. Download the Network cDAQ Recovery Utility .
  2. Remove power from the cDAQ.
  3. Press in the reset button and hold.
  4. Apply power to the cDAQ.
  5. Wait for the status LED to start blinking.
  6. Release the reset button.
  7. Run the Network cDAQ Recovery Utility.
