Do I Need to Use All the Inputs or Outputs of DAQ Device
Updated May 21, 2018
  • Multifunction I/O Device
My DaQ device has 2 Analog Outputs. Is there any problem if I only use one of them?
There is no minimum required channels to be used when working with I/O device, you can use them as your project requires.
