Temperature Measurement Range for PXIe-4353
Updated May 30, 2018
  • PXIe-4353
  • What is the temperature measurement range for PXIe-4353?
  • Does the PXIe-4353 measure below -100 °C?
The absolute temperature measurement range depends on the thermocouple been used. If the output voltage range of the thermocouple falls within the voltage measurement range of the module (±80 mV), you can measure on all the thermocouple range.
The PXIe-4353 temperature input module provides integrated data acquisition and signal conditioning for temperature measurements.
