Can I Adjust Drift on the 845x Between Different Lines?
Updated Apr 25, 2018
  • USB-8451
  • USB-8452
  • NI-845x
I'd like to make slight adjustments to the drift between lines on my 845x. For example, I'd like to set a specific drift between my clock and data lines. Can I accomplish this?
You cannot adjust the drift between lines on the 845x to specific values. The drift is specified in the 845x Hardware and Software Manual.
If you need specific drift values, consider using a more flexible digital device such as an R Series FPGA device or a FlexRIO device.
