Is the Voltage Supply (Vsup) on a USB-9472 Common Across All Voltage Supply Pins?
Updated Apr 18, 2018
  • USB-9472
 I am using a USB-9472 Digital Output Device, and want to know how to wire it, specifically is Vsup common across the device?
When using the NI USB-9472 Digital Output Device, the voltage supply (Vsup) pins are common across the entire device.
