Connection Type for the PXIe-2748
Updated Jun 5, 2018
  • PXIe-2748
I am buying cables for the PXIe-2748, and was not sure if the connection on the front panel was male or female. Which type of connector should I purchase?
The connection on the front panel is a female connection. Thus, you will need a cable terminating in a male connection to interface with the card.
This information can be found on page 5 of the PXIe-2748 specification sheet. The connectors are defined as jacks, which indicates that it is a female connection. Cables defined as plugs indicate male connections.
