Copying and Creating a New Sub Panel on My Front Panel Does Not Change Name of Sub Panel
Updated May 17, 2018
I put a Sub Panel on my Front Panel and created another one be Ctrl+Click and dragging a new one onto the the same Front Panel.  The Sub Panels have the same name and when I create Invoke/Property Nodes for them I cannot tell the difference between them on my Block Diagram.  How do I tell the difference between them?
When creating multiple Sub Panels on a Front Panel, you need to change the Label in order to distinguish between the objects on the Front Panel and Block Diagram.  You can also double click the nodes on the Block Diagram in order to highlight the Front Panel Objects they correspond to.
