Front Panel Table Flashes When Code is Ran
Updated May 2, 2018
I want to stop my table from flashing whenever I run my code. I'm reading in values from an array, and all of my code is inside a while loop so that the table updates constantly.
The flashing or flickering is caused by LabVIEW constantly rebuilding the table with each iteration of the while loop. Moving the code that builds or initializes the table outside of the while loop should fix the issue.
Consult the the Block Diagram section of the LabVIEW Style Checklist for best practices with using loops.
