How Do I Install the NI VeriStand Model Framework?
Updated May 21, 2018
  • VeriStand
I need to compile a model to use it with VeriStand, however the NI VeriStand Model Framework is not installed in my computer, how can I install it?
The VeriStand Model Framework is included with the general installer for VeriStand, to install it follow the next steps.
  1. Launch the VeriStand installer.
  2. Continue through the installation wizard unitl you reach the section that allows you to select which features to install.
  3. Click the box next to the VeriStand 201X Model Framework option and select Install this feature to a local drive.
  4.  Continue through the installation process and once complete, the VeriStand Model Framework should be working on your computer.
