Power Options for AKD EtherCAT Drive
Updated Oct 18, 2018
  • AKD-P02406-NBEC-0000
  • AKD Series Servo Drive
  • LabVIEW SoftMotion Module
I am using an AKD EtherCAT drive and the specification lists several AC Voltages for supplying power.
Can I use any of the voltages listed?
Yes, the AKD drives are rated to operate at the voltages listed. As long as you are supplying a listed voltage with the correct 1 or 3 phase wiring (See page 104 and 105 of installation guide) for your device and power supply, you will be able to power your device appropriately.
