Increase EtherCAT PDO Rate
Updated May 17, 2018
  • cRIO-9039
  • LabVIEW Real-Time Module
  • NI-RIO
I am using EtherCAT to communicate with a third party controller that updates its PDO variables faster than I am reading them on my Real-Time (RT) target. How can I read them faster?
You can increase the Scan Engine Rate to increase how quickly you can read your PDO's.
Right click on your RT target in your Project Explorer and select Properties.
Choose Scan Engine from the Categories selction and you can edit the Scan Period.
The Scan Engine is recommended for applications running at 1 kHz or slower. Anything above this may experience performance issues depending on how much the Scan Engine is being used.
