How to Increase Font Size in Data View Time Graph in SignalExpress
Updated May 21, 2018
  • SignalExpress
I am using SignalExpress 2015 and cannot find how to increase font size in Data View time graph. I want to see larger numbers and letters of the graph in this tab.
SignalExpress is a configuration based environment rather than a development environment (such as LabVIEW). Because of this, settings such as the font size remain constant.
If you want to view your data in a larger format you can choose “1 Sample (on Demand)” as your Acquisition Mode and in the Data View tab right click>> View As >> Large Display. Then right click in the area >> Signals>> Add Signal >> Choose the signal you want to display from the list.
