Observing Data Measured by Two different Modules in One Graph Panel through InstrumentStudio
Updated Nov 2, 2019
  • PXI-5114
  • InstrumentStudio
  • NI-SCOPE
I purchased and have used two PXI-5114 Scopes. I want to see the signals being measured by two different scopes in one graph panel through InstrumentStudio. What should I do?
Unfortunately, you can't observe the signals being measured by two different modules in one graph panel through InstrumentStudio.
In InstrumentStudio, you need to create another graph panel to observe the signals measured by each module separately like following picture:
If you want to observe all of them in one graph panel, you should use LabVIEW.
