How to Reroute Input Clock Signal to Output Clock Signal in HSDIO Module?
Updated Oct 30, 2019
  • PXIe-6544
  • NI-HSDIO
Programming Language
  • LabVIEW G
I'm using a PXIe-6544, and I want to get the external clock signal back out of the module. Is there a way to reroute signals?
It is possible. First, specify the clock signal input to CLK IN as the sample clock of the HSDIO card. Thereafter, export this sample clock to CLK OUT. Please refer to the figure below for the API and method to use.
