Veristand: Unable to Initialize the NI Veristand Model Framework
Updated Dec 6, 2019
  • VeriStand
  • VeriStand Model Framework
Other
Simulink
I am trying to compile a Simulink model, whenever I attempt to compile it I receive the following message on the console:
Warning: A problem occurred initializing or executing an NI VeriStand component. Error detected was: Error using NIVeriStandAddPaths (line 84)VeriStand: Unable to initialize the NI VeriStand Model Framework. This release of Simulink(R) is incompatible with NI VeriStand. For more information, visit ni.com/info and enter the Info Code ex8sn9.
This issue can be caused by 2 different situations:
  • This warning means that you are either missing the VeriStand Model Framework or this software component is corrupted. You can install this software by following this guide: How Do I Install the NI VeriStand Model Framework?.
  • Simulink is missing the Simulink Coder. You can check the installation of Simulink Coder with the following command: ver('simulinkcoder')
