Multi Channel Support for Keysight AG3352X Drivers
Updated Nov 7, 2019
  • Keysight AG3352X Driver
I have a multi-channel keysight device, but the drivers only have single channel VIs. How do I implement multi channel calls for my instrument?
The Keysight driver VIs can be split into two categories: Resource dependent VIs, and Channel dependent VIs.
Resource dependent VIs (like ag3352 Initilize.vi) only have the resource name as a device specifier. This means that when you call this VI, it will affect the entire device. These VIs are usually only called once per task
Channel dependent VIs (like the ag3352 configure standard waveform.vi) will have an input to specify the channel. These VIs can be called multiple times to implement multiple functions for difference channels.
The example below is a modified version of Generate Std Wfm.vi that supports 2 channels.
