How to Add the Module Time Column in TestStand
Updated Oct 25, 2020
  • TestStand
I want to display the Module Time column at run time. How do I configure this setting?
  1. Open your TestStand sequence file
  1. Right click in the blank space of the Steps: Main Sequence section
  2. Select Step List Configurations
  3. Select Edit Step List Configurations...
    1. Select Execution Times
    2. Select OK
    After completing these steps you should see the the Module Time column at run time as shown in the following image.
    To view the expressions used to add the Module Time column, follow steps 1-5 then complete the following:
    1. Click Edit...
    2. Select the Columns tab
    3. Select the _MODULE_TIME caption
