How Can I Modify Manually the ICS Parameters Value
Updated Oct 24, 2019
  • Micropross Accessories
Other
SW : MPManager 3 / EMV PICC Digital test suite
In the test suite settings, I choose “Auto-detect ICS”. However, is there any place where we can manualy input the correct ICS parameter?
The ICS file is stored by MPManager 3 in :
C:\Users[UserName]\Documents\MPManager\EMV PICC Digital\ics_v3_0.xml
Open in with a text editor in order to modify it.
Please note that the variables names in the .xml files are not matching the control labels in the user interface.
No correspondance table are existing as the xml file is using the programming variable name.
