How Do I Change the Language of the Installer in LabVIEW?
Updated Nov 5, 2019
When I build the installer of the LabVIEW project, the installer is built in the language for the version of my LabVIEW. I want to change the language of the installer in my customer's language. How can I resolve this problem?
Basically, the default language of the installer is the version of LabVIEW you currently use. You can set the language of the installer in My Installer Properties dialog box. If you change the language, the installer dialog boxes, error messages and other user interface text in installer dialog will be changed.
Navigate to Build Specifications »  Installer »  Dialog Information »  Language like below.
You can select the language among German, French, Japanese, Korea and Chinese(Simplified).
