GPIB NI-488.2 Board Interface Overflow Error
Updated Dec 4, 2019
  • NI-488.2
I am using the NI-488.2 drivers and I get the following overflow errors when compiling my code.
An error was encountered while opening the meters...System.OverflowException: Arithmetic operation resulted in an overflow.
This error can happen when the development environment is not pointing to the current or correct drivers.
  1. Re-install a compatible version of NI-488.2 by cross-referencing the hardware and operating system compatibility.
  1. Re-link the drivers using the standard process for your IDE.
