Starting from LabVIEW 2018, the
Controls palette includes the new
NXG Style of front panel controls and indicators. Use the NXG style controls and indicators to create front panels with the same style as LabVIEW NXG. The appearance of these controls and indicators changes depending on the platform on which end users run the VI. Using these controls and indicators minimizes distortion of your front panels if you migrate the VIs to LabVIEW NXG.
Below you can check and example of a simple UI developed with these controls:
