Custom bitfiles can be loaded using the NI-RFSA function niRFSA Initialize with Options and passing in the correct DriverSetup property into the option string input parameter. The correct syntax for passing along the DriverSetup property is as follows:
DriverSetup=Bitfile:<Bitfile Name>.lvbitx
The driver bitfile must be present in following folder: <User>\Public\Documents\National Instruments\FPGA Extensions Bitfiles\<Target Name>
For the PXIe-5668R, the target name correlates with the PXIe-5624R digitizer module. An example of loading a custom bitfile for the PXIe-5886R in LabVIEW is shown below.
