How to Communicate with Two Reader and Writer Endpoints with One IP in a Network Streams
Updated Oct 30, 2019
  • CompactRIO Controller
Is it possible to communicate when creating two reader and writer endpoints with one IP in the network streams? I modified and tested the code based on the network streams shipping example provided by NI, but the data communication was not working properly.
Network streams are an easy-to-configure, tightly integrated, and dynamic communication method for transferring data from one application to another with throughput and latency characteristics that are comparable with TCP. And, Network streams are designed and optimized for lossless, high throughput data communication. You can see more detailed information about NI Network Streams technology in here: Lossless Communication with Network Streams: Components, Architecture, and Performance
The NI Network Streams shipping example is configured to communicate using one Reader and Writer endpoint on one common IP. If you want to use two Readers and Writers, create two endpoints and specify Reader 1 and 2, and Writer 1 and 2.
Here's how it looks like this in LabVIEW code:
  • Host code of the Network Streams
  • Target code of the Network Streams
