What Version of Xilinx Compilation Tools Does LabVIEW FPGA Use?
Updated Nov 27, 2019
  • LabVIEW FPGA Module
  • FPGA Xilinx Compilation Tools
I need to know what Xilinx compilation tool is being used to compile my FPGA VIs. I have found a table online, but it does not show the exact version of the compilation tool.
When compiling an FPGA vi, you can check the Xilinx compile log. You can find the Xilinx Log in the Compilation Status Window.
Select Xilinx Log in the Reports Dropdown menu. It should show the Vivado compile tool that your LabVIEW version uses.
