Reading Delimited Spreadsheet on cRIO
Updated Oct 22, 2019
  • cRIO-9035
When I am using Read delimited spreadsheet VI on my cRIO, it is not working. I do not get any specific error, the VI just stops without any result. Is this function usable on RT targets?
Yes, you can use this function on RT targets.
This behavior most probably is caused by inputting wrong or faulty  path to this VI. In general, this situation should be noticed by LabVIEW and pointed out as an error.
However, it will not happen, if you disable automatic error handling in VI properties.
More information about proper path syntax can be found in this tutorial.
