Follow the below troubleshooting steps to resolve this error:
Reset the Cached NI User Account File
Close LabVIEW, NI License Manager, and all other NI software.
Open File Explorer and navigate to:
%localappdata%\National Instruments\UserAccount\
Delete or rename:
Configuration.xml
Launch the affected NI software again.
Deleting this file only resets cached NI User Account information. The file is recreated automatically when the application starts.
Repair NI Measurement & Automation Explorer (MAX) and NI System Web Server
- Open NI Package Manager.
- Select the Installed tab.
- Select Products only.
- Locate and select NI Measurement & Automation Explorer
- .Clear Products only.
- Locate and select NI System Web Server.
- Select Repair.
- Restart the PC if prompted.
Verify Network, VPN, and Proxy Configuration
If the computer is connected to a corporate network, VPN, or proxy server:
Test the software on a different network, if available.
Contact the local IT administrator and verify that outbound access is allowed to the following endpoints:
delta.ni.com (TCP 443)download.ni.com (TCP 80, 443)ni.com (TCP 80, 443)
Repair the Affected NI Software
Repair any NI software package that displays this error.
- Follow the steps in Repair Software in NI Package Manager (NIPM).
- Test the software after the repair completes.
Update NI License Manager
- Download the latest version of NI License Manager that is compatible with the operating system.
- Review the Supported OS section on the download page to confirm compatibility.
- Install the update and restart the computer if prompted.
- Launch the affected software and verify that the error no longer occurs.
